Author Topic: How to launch Musicbee without playing music?  (Read 1488 times)
Philippe
Regards
Philippe
Edit->Edit Preferences->Player...on startup: do nothing or resume position.
Philippe
Thanks Frantz for your quick reply,
I already do that but nothing :-(
Still launch music ta starting.
How do you open the program?  Does your shortcut to the program contain anything that would resume playback despite the setting (is that even possible?).  What happens if you go directly the the exe in File Explorer and open it that way rather than via a shortcut?
Philippe
You are right. It works if I use the windows shortcut on the desktop.
In fact I had forgotten that I was using a keyboard shortcut to launch MusicBEE with a .BAT file  :-[
I just changed it :
@echo off
cd "C:\Program Files (x86)\MusicBee\"
REM start MusicBee.exe /play /next
start MusicBee.exe
Thank you very much for your help.
Regards
Philippe
Last Edit: August 29, 2020, 09:56:37 AM by Philippe
