Author Topic: Remove picture  (Read 2728 times)
gorney
It is set to auto-retrieve missing artwork for the playing track but not set to save without prompt.
First, UNCHECK "Auto-retrieve missing artwork."  Then, from the menu on top of MusicBee, go to Tools->Advanced->Reset Artwork Cache.  After the reset, exit and then re-open MusicBee.  Do you still see the picture on the file in question?  My bet is the picture was neither embedded nor a file in the audio file's folder, but just what gets left in the cache after an autoretrieve-but-don't-save operation.  That cache has to be periodically cleared manually with the "Reset Artwork cache" command as it is not auto-deleted on exit.  The same thing happens in auto-retrieve lyrics without saving, although that cache folder is elsewere and has no menu command available to clear it (but see https://getmusicbee.com/forum/index.php?topic=29365.msg163645#msg163645).
Last Edit: August 24, 2020, 02:14:52 AM by sveakul
gorney
Thanks. It's now playing tracks without artwork, but Search Internet for Picture is now working, whereas it was not before.
Last Edit: August 24, 2020, 02:34:22 AM by gorney
