Author Topic: Album Tiles  (Read 12450 times)
  • MB Version: 3.6.8849 P
Sort of a hybrid between the old Album Wall and the newer Metrology/Fluent versions
Album Tiles
Download from Theater Mode section of MusicBee Add-ons here
Uses first 20 tracks.
Adjust the numbering in the xml if you want to use less/more.
Last Edit: August 21, 2020, 01:06:19 AM by Bee-liever
mmakes
Mixing album covers and artist pictures is a cool idea! Awesome job!  :)  8)
(I might copy that idea :P if you don't mind)
Serminator
Quick question: any way to easily change the color of the progress bar and visualizer?  Thank you.
Only by editing the .xml file.
The parts you need are in the last 3 sections.
The colors are in RGB format (0,0,0 = black / 255,255,255 = white).
If any of the settings has a 4th value (x,R,G,B) than x is a transparency value from 0 to 100.
