Author Topic: Physical tag  (Read 744 times)
clausskou
I have ripped some of my physical cd's. And intend to keep the physical cd. I would like to mark the songs in MusicBee that I still have the physical cd in order to keep track of this.
How have you done in MusicBee? Added a tag?
Looking forward to hear your experience.
alec.tron
Hi, check:
Preferences -> Tags(1) tab -> Define Custom Tags
Should be well documented how to use this.
c.
SonicRings
There are plenty of ways you can go about doing this. I'll outline a few.
Put them all in the same folder.
Add a "LABEL" tag and name it something unique (such as "Physically Owned") so they will show up when you search for that label.
Add them all to a playlist and go into album view in that playlist.
I'd personally go the Label tag route.
This is what I've done. I have a custom tag called "Owned" that says CD, LP, download, etc.
Last Edit: August 19, 2020, 03:47:39 PM by psychoadept
clausskou
T
Hi, check:
c.
Thanks for the help. Just what I need.
