Author Topic: R0003 - File System Copy/Paste  (Read 2030 times)
StellarWind
I use the Storage view of the file system to view the contents of a uSD card on my laptop when traveling.  This is when I test drive new music, tag it, classify it, etc.  When I get home, I move these songs from the uSD to the main collection on a separate computer.  I use two directories "To Process" and "Ready to Import".  So if I have a new music collection to audit ("My New Album"), I start with that being inside of "To Process".  When done, I move it to "Ready to Import".
Can you add a feature to:
a) Allow Folder Name --> Right Click --> Cut.  Then destination directory ("Ready to Import") --> Right Click --> Paste.
b) Allow directory moves from within MusicBee using drag and drop.
This feature existed in MediaMonkey so I made heavy use of it.
You can do both of those things in the Computer node in the left sidebar.
I think it's enabled by default, or you can go to Edit > Edit Preferences > Layout (1) to enable it.
StellarWind
'\Computer' was already enabled.  It only shows C:.  I'm working off an SD card which is mounted as E:\ and located in the Tree under \Devices\E:\Storage.  Under that, there is no Cut/Paste.
Right-click on 'computer' in the left sidebar > manage folders > choose filtered folders. Once chosen you can decide to show -only- the filtered folders or -all- folders.
StellarWind
It was already set to Show All Folders.  Also, if I select "Choose Filtered Folders", E:\ does not show up in the list.
I think sd and usb drives won't show up in the computer section. They should show up as devices, though, which will still let you access the files on them.
StellarWind
I think removable drives won't show up in the computer section. They should show up as devices, though, which will still let you access the files on them.
It does, but Cut/Paste is missing from under \Devices\E:\Storage\xxx\yyyy\zzz\.
That is already supported. However by default folder drag/drop is disabled.
On the Computer node, right click/ Manage Folders/ Allow Folders to be moved
StellarWind
That is true, under the Computer Node, however, the microSD card does not appear under Computer.  It appears under Devices --> E:\ --> Storage  only, which has no option to 'allow folders to be moved' and has no Cut/Paste context menu.
yes i know. The option can be set from the computer node as instructed
StellarWind
