Author Topic: Option to exclude Banned/Unticked files from syncing.  (Read 1234 times)
bigdonkey1
Would it be possible to add a filter/check when syncing that excludes banned/unticked songs from being synced?
Itunes has had this as one of it's few syncing options for over a decade, simply offering "sync only ticked songs" and the lack of it in musicbee involves a ridiculous amount of bending over backwards to get around, especially when syncing a large number of playlists or a full library that contain multiple banned tracks.
bigdonkey1
been 3 years and still waiting on this. the functionality is there if you aren't syncing playlists but then banned tracks are synced by default, the second you swap over to playlists to filter out banned tracks the unticked tracks start syncing.
Create a filter to exclude the tracks not wanted and sync the filter.
bigdonkey1
Syncing Playlists ignore the filter and still sync unwanted tracks
