Author Topic: Option to Hide Icons in the Tab Bar  (Read 2713 times)
mmakes
When I right click on a Tab, there are options only to display Icon+Text or Icon Only. Can there be a Text Only option?
Example:
Top is the original. Bottom is the desired result.
I can fit many more tabs and have a cleaner interface if I can remove the icons. Thanks a lot  :D  :D  :D
Are those tabs all pinned? When not pinned only text displays
Clarity
+1 for text only while pinned
Meanwhile, Windows has a huge range of suitable and creative symbols / text icons that can be used via [Win]+ [.] or via fonts such as Segoe UI Symbols. In this way, every user can simply bypass the icons specified by the skin developer and individualise them as desired or, if they don't need any icons at all, save space without unpinning the tabs. I would love this option being added.
Text Only tab pin is supported in the next v3.5 update
