Author Topic: How can I remove icons from the Tab Bar?  (Read 1976 times)
mmakes
When I right click on a Tab, there are options only to display Icon+Text or Icon Only. Is there a Text Only option?
Example:
Top is the original. Bottom is the desired result.
I can fit many more tabs and have a cleaner interface if I can remove the icons. Thanks!
A text-only option does not exist.
If it's very important to you, I suggest creating a request in the Wishlist section for possible consideration.
mmakes
Thanks for the reply! I'll put it on the wishlist then.
The Incredible Boom Boom
Example:
Messing around with one of these may do that.
<element id="TabsBar.InactiveTabInCaptionIconMask" bg="225,0,0,0" /> <!-- 204,184,141 -->
<element id="TabsBar.InactiveTabIconMask" bg="225,0,0,0" /> <!-- 151,225,209 -->
<element id="TabsBar.AltInactiveTabIconMask" bg="0,0,0,0" bg2="0,0,0,0" /> <!-- 151,146,209 -->
<element id="TabsBarPTop.InactiveTabIconMask" bg="0,0,0,0" /> <!-- 240,238,153 -->
<element id="TabsBar.TabInCaptionBarBlended.InactiveTabIconMask" bg="125,60,240,60" /> <!-- 60,186,109 -->
<element id="TabsBar.InactiveTabInCaptionTopIconMask" bg="255,0,0,255" /> <!-- 188,140,195 -->
That could accomplish making the icons invisible, but it won't free up their space.
Ah, yeah, I didn't notice the spacing was different in the bottom shot.
mmakes
