Author Topic: Sort playlists by created date  (Read 1804 times)
anataky
Hello,
I created some static playlists in MusicBee, but it doesn't looks like what I'm expect.
It looks like those playlists sort by name by default:
But I want them sort by created date like in Foobar 2000:
And I couldnt find how to change the sort method in Playlist Explorer.
How do I change the playlist sort method to the "sort by created date"?
Thanks.
Last Edit: August 17, 2020, 05:10:37 PM by anataky
Its not supported. If its important to you then add this request to the wishlist
anataky
Thanks for your reply.
Yes, its important to me. I would appreciate it if you would add this request to the wishlist.
How it works on this forum is that you create your own wishlist topic.
Or if you ask nicely a mod can move it :)
anataky
I've noticed the topic is already moved to the wishlist.
Thank you guys for this. ::)
