Author Topic: Let MusicBee Recgonize FiiO  (Read 1133 times)
Batphones
  • I Smell Like Teen Spirit
We all have used iTunes/iPods I am sure, and we all know that when we had to put music on our iPods we had to open iTune plug our pods into the usb port on a computer. From there an iPod icon would appear in iTunes allowing you to see what was on it, and giving you options to add or delete music from it. What I was wondering if we could get MusicBee to do that same thing with FiiO. That way everything is in one place and it would just make it easier. Is this possible?
When you plug in the FiiO it should be appearing under Devices in the left sidebar.  If that's not happening you should make sure the device is unlocked before you connect to USB and that it's set to USB Transfer (or something like that.) That's the way it worked when I worked my way through two or three FiiOs before giving up on the brand.
