Hey guys,
Problem:
When moving into a new network the app should be able by itself or provide an option to relocate the MusicBee server.
Description:
I've been using MusicBee & MusicBee Wifi on my Android Phone since it came out. Worked perfectly in my old network.
A month ago I moved to my new flat and yesterday I was not able to sync my music wirelessly (even I did it with cable before).
So I reinstalled the MusicBee Wifi app and it showed a button to locate the server. I used this option and the wifi sync works now again.
I guess the App somehow saves the location/IP of the server and is not possible to search for the new server, once it had found and connected with a server.
Could you add an option in the App Settings maybe (or in the problem management) to relocate the server?
Thank you
Pete
