Author Topic: .xml Theaters mode, how to find fields Id  (Read 9484 times)
Jimolrame
I am doing an xml plugin for the theaters mode. For now, most of the elements I want to call ( like id="Tracks[1]" etc) I checked from other available plugins.
I am looking for other information which does not seem readily available : format, encoding (bitrate, freq) Stereo etc. I checked in https://musicbee.fandom.com/wiki/Tagging, but nothing I tried did work.
Where/how could I find these specific ids (and others) ?
Thank you
The Incredible Boom Boom
In the ~\MusicBee\Plugins\TheaterMode.List folder there's a ReadMe.txt that has a list of some of the fields available. I think some of them that aren't list specifically can still be used, but it would be trial and error to figure them out.
Freddy Barker
  • 🎧 MB 3.4.7628P
Thank you
You can use Custom Tags to define your own fields, and in the XML, (for example) use 'Virtual1'
Virtual1
LABEL:
Days Since Played
FORMULA:
$If(<Last Played>="Unknown",???,$NumberOfDays($Now(),<Last Played>))
Freddy
Jimolrame
Thank you.
The text file helped for another issue (Rating / RatingLove while it is still disappearing when both are at 0).
I thought it was a bit simpler but I guess I will try with the Virtual, it should work with the bitrate /sample rate etc fields in the Track information.
EDIT:
Found exactly what I wanted with Virtual :
Formula :
$Upper($RSplit(<URL>,.,1)),  <Sample Rate>,  <Bit Depth> bits, <Bitrate>,  <Channels>,  <Time>
Last Edit: August 17, 2020, 10:43:46 PM by Jimolrame
