I have these settings , I can not find the volume analysis
If you right-click a file(s) you can choose SendTo: Volume Analysis.
I'm unaware that saving an album art image or lyrics as embedded tags would modify your file date even when "don't update file modification time when saving tags" is checked, not using that option myself--you have tried doing it, and is that indeed what happens?
Off-topic I noticed your auto-tagging lyrics sources; I would recommend adding Genius to those which I find grabs the majority of searches I do. I'm assuming you are using the Lyrics Reloaded plugin maintained by frankz.
hi
i guess can edit tag without changing timestamp , i have read in the changelog
honestly i should try to with new files , i will rip a cd soon and let musicbee add cover , lyrics and cd tags years ,name and so on
i have noticed with Volume Analysis (is like replaygain ?) , it does change the timestamp
no i'm not using it , and how can genius auto-tagging lyrics?
does it change timestamp?
in short i don't want to change timestamp of my songs
thanks
