Author Topic: Functions $Contains and $Ismatch not working properly, or is it my fault?  (Read 1477 times)
stardot
I am using the function $Contains to search for a certain word in the field <Artist>.
So if I wrote this in the artist filed : Artist with Artist
then I wrote in Virtual Tag $If($Contains(<Artist>,"with")="T", <Artist>,)
that does not work.
Why?
Thanks
Last Edit: August 08, 2020, 07:23:23 AM by stardot
Is the typo in "with" copied from your actual virtual tag? Also, Contains should be $Contains.
stardot
Oh this was a typo from me. But in the software it is written as it should be.
Hmm. It looks like it should work, then. Can you post a screenshot of the virtual tag with the results? (What you get if you click the [...] button by the virtual tag, and then "Preview".)
stardot
Sorry there is more to the characters involved in the field <Artist>.
It is actually : "Artist (feat. Artist)"
And then I put: $If($Contains(<Artist>,"feat")="T",<Title>,)             <----- This doesn't work.
The screenshot will still be the most helpful thing at this point.
stardot
As you can see, only track number is in the result, but the title is not there.
The Incredible Boom Boom
that does look like a bug so i will look into it
Could you explain what the bug was? I use lots of $Contains() and $IsMatch() functions and haven't had any issues with them, so if I was unconsciously working around a bug, it would be good to know what's going on, so I can adjust my functions accordingly. Thanks
Last Edit: August 08, 2020, 04:32:11 PM by The Incredible Boom Boom
