Have you ever tried using 'Album Art Downloader' as an external tool?
https://sourceforge.net/projects/album-art/
Via Tools > External Applications you can set it up using specified tags.
Yes, Thank you.
It was the first method I used to do but it opened a new window for every search or query. Although I still have it though. I hated the multiple windows.
while using chrome, I will search for multiple songs and it will open multiple tabs that happened to be familiar with me...
And the app does only one job... it's not multifunctional.
There's a setting in Album Art Downloader for "Open search results in new window" that is set to on by default, but you can turn that off.
Depending on how you configure it and how you use it you can avoid that. But that's not for this thread.
Oops
