Author Topic: GMMP and Musicbee playlists and files  (Read 1806 times)
tsheils
Hi
I use both Music Bee (mb) and Gone Mad Music Player (gmmp).
I've begun curating my music on mb anew (about 6000 songs).  And I drag about one-third of my music onto my motorola phone and listen on gmmp.
I also have created 2 playlists on gmmp (YES and NO) which I'd like to use to clean up songs on mb (if a song is NO I will delete it permanently and if it is YES I will keep it ... and later add ratings on mb ... and later add those songs to various mb  playlists.
Is there a simple way of syncing (wired) the two playlists?  Or, if not, perhaps a way of simply dragging the gmmp playlisted songs into 2 discrete locations on mb?
As the above shows, I'm a bit of a lunk about technical matters. https://getmusicbee.com/forum/Smileys/default/embarrassed.gif But the music really matters to me and I think these two programs will work out (and keep me free of the corporate/internet giants).
So, thank you for any help.
tsheils
PS
I have tried importing the YES playlist and "the following playlist failed to import" ... and yet a non functional playlist by that name is found in c:\storage\0\music\...  , and mb does show the list as seen in the screenshot linked below
https://imgur.com/qfgB1kv
Thanks again for any help.
