Author Topic: Album ratings must be set before using auto-calculate.  (Read 739 times)
tuivlacic
I'm using version 3.4.7495.
I'm using the Album Covers view and I have 'auto-calculate album rating' on.
What happens is that the auto-calculated album rating isn't appearing normally.
For every album, I have to disable that setting, rate the album with any value, and enable the setting again.
After that, it appears and updates properly.
It would be better if we didn't have all the trouble of turning the setting on and off again for every album.
Also: turning the setting off shows that the auto-calculated rating isn't being saved on the file even though I have 'store ratings in the music file' setting on. Is it proper behavior? Does it apply only for track ratings?
