Author Topic: Podcast Sync Folder Wrong  (Read 841 times)
nightsurfer
I have been unable to find a suitable answer on the forum,  so forgive me if it does already exist.
I'm trying to sync podcasts to a folder on my phone called Podcasts but MB insists on putting them under Music.
They are correctly listed in MB as podcasts.
This is a link to a screenshot of the settings box:
https://imgur.com/mn40IoX
Hopefully someone will be able to point out where I have gone wrong.
Thanks
Are you sure that this is the profile that's actually in use?
Sometimes, multiple profiles will exist for the same device for some reason, and if you're using wifi sync it's hard to know which one is being used at the time.
nightsurfer
this is the only profile.
I am using a USB lead to connect to the phone from my PC
