Author Topic: Track Information on the Main Player when Wave Bar is selected!  (Read 1133 times)
SpirosG
As i mentioned earlier when you select the Wave Bar instead of progress bar track information is missing form the main Player.
If you select to use the wave bar instead of the progress bar the track information are not available.
Steven informed me about that
Thats expected behaviour. The playing track information is displayed in the status bar when a wavebar is displayed in the player controls panel
I would love to be able to use the Wave Bar but to also keep the Track information in the Player instead of moving them to Status Bar
Last Edit: July 23, 2020, 05:52:37 PM by SpirosG
minsky
To people came here from Google:
In the panel configurator window, simply drag the "wavebar" element from the list on the right to the "bottom panel" section.
Not sure if this element is available in older versions; I'm on 3.5.
