Author Topic: Tags, Images etc keep getting removed  (Read 659 times)
e8ghtmileshigh
I spend far too much time organizing my library only to find much of my work erased. What is happening?
Do you really expect anyone to be able to help you troubleshoot with the information you've given?
A little detail as to what you're doing and what you're seeing as a result would help.
e8ghtmileshigh
Like I said, album images and some tag information are randomly disappearing
If you still use WMP, then WMP can automatically overwrite tags without any prompting.
If its not the case you use WMP, then you really need to provide a detailed description of what activities you do, otherwise no one will be able to help you
