Any idea on how to actually do it, though? I'm not super familiar with MusicBee's code. Is there some way to count a numerical tag, so I would count the number of tracks in the newly made auto-playlist?
I only have about 4 virtual tags, and none go as in depth as this would require.
I thought Track Count would only count the tracks available, but it looks like it is if you have the total in the tags, and Album Track Count will count all the tracks for that album regardless of whether or not you have the total number. My bad on that.
You could maybe set it up to compare the maximum or highest Track# value in the auto-playlist to the Album Track Count. If it's the same, then all values should have ratings. You'll need to play around with the coding though to make it work, since I'm not 100% sure on how that would come out.
