Author Topic: Is there a way to sync to phone the way that WMP does?  (Read 1585 times)
e8ghtmileshigh
Drag and drop files/albums/artists directly from the app
Hi, welcome to the forum!
I think you could do that within MusicBee, drag to the device in the left sidebar.  If you try it and it doesn't work you can post a wishlist request. I don't think you can drag and drop to Windows Explorer or something, but I could be wrong.
e8ghtmileshigh
That works the same way as drag and drop directly into memory. i'm looking for a way to drag files in to a queue, before syncing, like in WMP.
You could put them in a playlist and sync the playlist.
You might find this page helpful:
https://musicbee.fandom.com/wiki/Devices
You can drag a track or album or multiples of either from MB to WE. Personally I use XYplorer, but I just tested with WE and it worked.
Download the latest MusicBee v3.5 beta patch from here.
Check out the MusicBee Wiki.
How to post screenshots is here
e8ghtmileshigh
I don't want to merely drag and drop files into the phone memory, I want to create a queue of files first and then import them in one go
https://getmusicbee.com/forum/index.php?topic=32165.msg177257#msg177257
