Author Topic: MusicBee 3.4  (Read 221207 times)
**** see the last post for the latest update ****
The beta series for v3.4 has started and will be updated with more enhancements over the coming months. See the last post for the most recent download link.
Follow https://twitter.com/MusicBeePlayer for notifications when updates are made available
https://www.dropbox.com/s/51o8e943qsriuyg/MusicBee_Setup_3_4_7499.zip?dl=1
backup
https://www.mediafire.com/file/jhlhc48yne19876/MusicBee_Setup_3_4_7499.zip/file
this is an incremental update and includes all changes since version 3.3 - unzip and then run MusicBee_Setup_3_4_7499.exe
- New Jukebox view - see: https://getmusicbee.com/forum/index.php?topic=24864.0
- Lock Playlist command disables changing the content of the playlist and also deleting or renaming the playlist
- Cut and Paste supported for moving tracks in playlists
- For playlists that are configured not to refresh, right click/ List/ Refresh Now refreshes the playlist
- When shuffling tracks loved tracks are treated as maximum rated
- M3U(#EXT) now supported for MTP devices
- In the Music Explorer Albums are now split into a separate "Appears On" section where the criteria is the album artist differs from the current active artist selected in the Music Explorer
- Undo file move command
- The Send To/Add to Playlist command now shows the most recently used playlist for quick access
- "Love" rating is saved as a tag
- Larger album artwork size supported in the Album Covers view
- Download manager now supports Stop All downloads
- Pitch and Sample Rate can now be controlled from the Tempo DSP plugin
- Playback speed can now be controlled using right click on the Player controls panel
- Mouse wheel speed can be slowed down as set in the General Preferences panel
- Podcast mark as listened now supports streamed episodes (previously only downloaded episodes were supported)
- Podcasts panel can now set and filter loved subscriptions
- Particular podcast subscriptions can be set so episode updates are checked manually
- For standard skins the last.fm icon can be hidden in the player controls panel using right click/ Panel Layout/ Show Last.fm Scrobble Button
- Auto-DJ custom filter presets can be saved and loaded
- You can now specify different artwork for an album (that is displayed in the main panel Album Covers view) to the primary picture for each track in the album that is displayed in the playing Track Information panel. Its set in the Preferences/ Tags(1)/ artwork/ set which pictures are displayed/ Edit List dialog
- Chapter tags now supported for mp3 and ogg/opus/flac files (already supported for m4a files)
- Album Auto-tagger now updates cuesheets
- Virtual tag text Markup ({color},{font},{contrast}) now supported in the expanded panel for the Album Covers view
- Free DB is no longer supported eg. when ripping CDs, MusicBrainz is used
- $RxMatch(<field>,regex-pattern) function that returns the text portion that matches a regex pattern
- Column Browser now supports up to 8 fields
- Improved handling for windows shutdown while musicbee is running
translator file - updated new.txt file (this file is only used by translators and not required for the MusicBee application update):
https://getmusicbee.com/patches/new3.4.txt
edit:
links updated to fix a bug with the JukeBox view being used for playlists
Last Edit: August 08, 2020, 08:59:05 AM by Steven
https://www.dropbox.com/s/3p4vixpwsnisb6m/MusicBee_Setup_3_4_7525.zip?dl=1
backup
https://www.mediafire.com/file/ycu3brqgnjoyonw/MusicBee_Setup_3_4_7525.zip/file
this is an incremental update and includes all changes since version 3.3 - unzip and then run MusicBee_Setup_3_4_7525.exe
- new tag hierarchy panel that allows you to create your own nested hierarchy based on tags (most people would use genres)
- see https://getmusicbee.com/forum/index.php?topic=8987.0 for a couple of presets
- and https://getmusicbee.com/forum/index.php?topic=32471.0 for the background to this functionality
- various bug fixes
Last Edit: August 30, 2020, 10:23:43 AM by Steven
https://www.dropbox.com/s/ty8q6pr5yyr4pgy/MusicBee_Setup_3_4_7547.zip?dl=1
backup
http://www.mediafire.com/file/1lem2lbf7rlpi09/MusicBee_Setup_3_4_7547.zip/file
this is an incremental update and includes all changes since version 3.3 - unzip and then run MusicBee_Setup_3_4_7547.exe
- Additional radio station directories now supported including TuneIn and Radio Browser
- Command buttons now support query filters eg. you can configure a button to filter for Decades and clicking the button opens a selection panel where selecting a decade filters the main panel for that decade. You can use Ctrl-click to select multiple criteria. Its like the column browser except its not taking up so much space. Only fields that have an enumerated set of values can be used (genre, mood, occasion, etc).
- playlist mixers now allow you to define a query that is applied to all the mixer criteria
- various bug fixes
Last Edit: October 08, 2020, 09:37:53 AM by Steven
https://www.dropbox.com/s/pk965hre1w427eb/MusicBee_Setup_3_4_7586.zip?dl=1
backup
http://www.mediafire.com/file/yva57rc3mx70gbo/MusicBee_Setup_3_4_7586.zip/file
this is an incremental update and includes all changes since version 3.3 - unzip and then run MusicBee_Setup_3_4_7586.exe
- now supports automatic creation of a playlist when dragging files to a playlist folder
- option to always center lyrics (previously only synchronised lyrics were centered)
- PodcastIndex.com added as a podcast subscription directory
- theatre mode plugin now handles high-dpi screens with better scaling
- when the mini-player docked to the top or bottom of the screen, it now no longer appears in the windows alt-tab list
- logarithmic volume scaling setting now supported in wasapi exclusive and asio output modes
- lyricswiki now removed as its no longer available
- various bug fixes
Last Edit: November 17, 2020, 07:55:48 AM by Steven
https://www.dropbox.com/s/4398xmyycr2z6gc/MusicBee_Setup_3_4_7628.zip?dl=1
backup
http://www.mediafire.com/file/hznal6i7a5u4zz5/MusicBee_Setup_3_4_7628.zip/file
this is an incremental update and includes all changes since version 3.3 - unzip and then run MusicBee_Setup_3_4_7628.exe
- hotkey to collapse all nodes in a tree nodes panel eg. the tag hierarchy panel
- album covers and artist views can now be configured to show album tracks in a separate panel
- improved handling for high-dpi screens with theater-mode skins
- improved handling for high-dpi screens with skinned custom player controls panel
- more standardised UI handling for star rating selection
- play previous now remembers all play history for a session (previously it was restricted to when the playing tracks list was last set)
- various bug fixes
Last Edit: January 17, 2021, 07:19:17 AM by Steven
https://www.dropbox.com/s/j5dtunloqr4vgou/MusicBee_Setup_3_4_7691.zip?dl=1
backup
https://www.mediafire.com/file/ktcg2u9ycw9ac8u/MusicBee_Setup_3_4_7691.zip/file
this is an incremental update and includes all changes since version 3.3 - unzip and then run MusicBee_Setup_3_4_7691.exe
- manual sorting for playlists in the Playlists tab (click Playlists header button/ Manual Sorting)
- right click/ Add to Playlist now shows the playlists the selected file(s) are already in
- new hotkeys:
  - View: Toggle Show Left Main Panel
  - View: Toggle Show Right Main Panel
  - Web: Open Link (selected files)
- tag editor now compares the cached tag values with the actual file tags and refreshes/ alerts any discrepencies
- the configurable prompts in the Track Info panel now support text markup eg. override contrast, colour etc
- improved functionality for detecting missing and read-only files before running commands that update files (such as Volume Analysis) and improved feedback when a file cant be updated (eg. file is locked)
- various bug fixes
Last Edit: February 09, 2021, 09:42:48 AM by Steven
This is the final planned 3.4 update that has new features. I will do an v3.4 official release in the next couple of weeks or so.
https://www.dropbox.com/s/iiljhg3tzyavess/MusicBee_Setup_3_4_7708.zip?dl=1
backup
https://www.mediafire.com/file/9h1g74x1hirqam7/MusicBee_Setup_3_4_7708.zip/file
this is an incremental update and includes all changes since version 3.3 - unzip and then run MusicBee_Setup_3_4_7708.exe
- enable freedb (via gnudb.org) for cd ripping
- various bug fixes
translator file - no changes since last v3.4 update
Last Edit: February 28, 2021, 07:28:49 AM by Steven
https://www.dropbox.com/s/1dk1q1kjhp3t6qi/MusicBee_Setup_3_4_7732.zip?dl=1
backup
https://www.mediafire.com/file/5nydwdp1yu6em0v/MusicBee_Setup_3_4_7732.zip/file
this is an incremental update and includes all changes since version 3.3 - unzip and then run MusicBee_Setup_3_4_7732.exe
- various bug fixes
edit:
updated to fix a couple of bugs
Last Edit: March 07, 2021, 03:21:19 AM by Steven
First release candidate that also addresses changes in bing search results for artwork searches
Incremental update that includes all changes since version 3.3 - unzip and then run MusicBee_Setup_3_4_7735.exe
https://www.dropbox.com/s/6794ix1g712zp2o/MusicBee_Setup_3_4_7735.zip?dl=1
backup:
https://www.mediafire.com/file/n23hjuixtce0oyv/MusicBee_Setup_3_4_7735.zip/file
or the full download, including updates to skins and localisations
https://www.mediafire.com/file/feblbvjcv0v1ddd/MusicBeeSetup_3_4_RC1.zip/file
portable:
https://www.mediafire.com/file/t9ni51tpnnjeb5p/MusicBeePortable_3_4_RC1.zip/file
Last Edit: March 23, 2021, 08:11:35 AM by Steven
Second release candidate that also addresses changes in bing search results for artwork searches
Incremental update that includes all changes since version 3.3 - unzip and then run MusicBee_Setup_3_4_7749.exe
https://www.dropbox.com/s/ki0acfv41q452g8/MusicBee_Setup_3_4_7749.zip?dl=1
backup:
https://www.mediafire.com/file/w06y8dpuhpboar6/MusicBee_Setup_3_4_7749.zip/file
https://www.mediafire.com/file/0sdnvoh3vdd8ahs/MusicBeeSetup_3_4_RC2.zip/file
portable:
https://www.mediafire.com/file/wtyvnts1vbcewyz/MusicBeePortable_3_4_RC2.zip/file
Last Edit: April 04, 2021, 11:56:26 PM by Steven
This should be the final v3.4 release. I will update the main downloads page once the store version is approved
Incremental update that includes all changes since version 3.3 - unzip and then run MusicBee_Setup_3_4_7764.exe
https://www.dropbox.com/s/tjuq88hq1xd8e4e/MusicBee_Setup_3_4_7764.zip?dl=1
backup:
https://www.mediafire.com/file/670f5yhzdy5atxe/MusicBee_Setup_3_4_7764.zip/file
https://www.mediafire.com/file/w8bhvr9relceaxt/MusicBeeSetup_3_4.zip/file
portable:
https://www.mediafire.com/file/96w1zpgkwdqbcsj/MusicBeePortable_3_4.zip/file
Last Edit: May 02, 2021, 06:04:01 AM by Steven
As there are several important bug fixes, I plan to a new release in the next weeks
Incremental update that includes all changes since version 3.3 - unzip and then run MusicBee_Setup_3_4_7792.exe
https://www.dropbox.com/s/89v59fzmcibkoil/MusicBee_Setup_3_4_7792.zip?dl=1
backup:
https://www.mediafire.com/file/9jj120u2si9644h/MusicBee_Setup_3_4_7792.zip/file
Last Edit: May 15, 2021, 10:07:16 AM by Steven
Last Edit: December 28, 2021, 11:41:34 PM by Steven
Here are the latest links that include the full release with many bug fixes. I will update the main downloads page when it has been accepted in the windows store which usually takes a few days
Incremental update that includes all changes since version 3.3 - unzip and then run MusicBee_Setup_3_4_8033.exe
https://www.dropbox.com/s/zwt96yu699jphl5/MusicBee_Setup_3_4_8033.zip?dl=1
backup:
https://mega.nz/file/p8tmGJrY#flvvxJ2U0dcHQ4xeMFuUPg6wgs_LDhM9m-GoaY6B-UU
or the full download:
https://mega.nz/file/sosy3TbZ#L7GxWAaCb7vzXh1qRBU_KWCtksWAu9kpIssgLIPkLmE
portable:
https://mega.nz/file/Nw0EiZ5I#LYLzvORhhj982IpVFVD7dH19iRlIiQviWTv36jC21bA
