Author Topic: Skin XMLC files  (Read 3820 times)
enko
So I've found a few skins I like the look of, but they're in XMLC format, not XML.
Is there a way to view them? Are they structured the same way as the XML files?
Just started getting into editing skins, thanks for any help.
enko
Oh I see, thanks.
Is it possible to do this for changing skin elements themselves?
e.g. if I want a skin to not have the equalizer button in the bottom right
You will need the skin source files for that. You could try contacting the skin author
