Author Topic: Musicbee doesn't read tags from some mp3's when they use the ID3v2.4 [SOLVED]  (Read 2684 times)
SpirosG
Musicbee does not read tags from some mp3 files when they use the ID3v2.4 (files tags have been edited in Mp3tag)
PM me for a file link.
Last Edit: July 28, 2020, 01:00:26 AM by SpirosG
Just to cover the basics, have you selected these files and rescanned them?
SpirosG
Yes this didn't work, but this time what worked was to rescan the folders again, although this was able to fix the problem this time i faced this problem 3 more times this week and the only way to fix the problem was to convert the tags to id3v2.3. Then i convert them back to ID3v2.4 within Musicbee.
there is an issue with the file you sent and this should now work. You will need to rescan the files
SpirosG
Hi Steven i use the latest 3.4 version, i'm still facing the same problem with various files!
Tag inspector gives me this.
System.IndexOutOfRangeException: Index was outside the bounds of the array.
   at #=zij0K4i_MOAe8AaGRphtnFcw=.#=zK4Lrx5Kd50zh(#=zXkA5ol8ciXaKB6WwwdBL0iY= #=ze2KoGrEbGDdn)
SpirosG
if you PM a link to one of the files i will have a look
I'am uploading some files from various folders for better examination, i'll send you the link ASAP.
Check out the MusicBee Wiki.
It's working for me. I'm not sure what you've used to download it, but it's just being overly cautious.
And to be fair, it's true - this file isn't commonly downloaded, because 24 hours ago it didn't exist.
SpirosG
It worked for me too...
Maybe it's a Firefox thing...
SpirosG
Just an update,  after some testing the last few days the problem seems to be solved!!!  :)
Thank you Steven!
