Author Topic: Bookmark / Favourites in the Search and Replace panel  (Read 941 times)
mrbenn
I have a ton of regex searches in a text file to copy and paste in, as sometimes the history in the drop down pushes them off the bottom of the drop down menu history.
Is there / could there be a way to have a bunch of favourite searches stacked up in the panel or a context menu that just runs x / y / x search and replace on the selected files?
Thanks.
Couldn't you just make auto-playlists so the searches are available whenever you want?
mrbenn
My use case is changing things like V.A. to Various Artists or fixing separators, leading spaces, 01,02,03 vs 1,2,3 etc.
I'm basically asking for search and replace macros by another name.
