Author Topic: Manipulating MusicBee Library Data in a Spreadsheet  (Read 324 times)
I wanted to do a deep dive on data from my MusicBee Library as it related to a specific playlist. I basically wanted to prioritize a list of albums by playlist inclusion and ratings.  Luckily, MusicBee provides facilities to export most library data for things like cross-tabulating.
This isn’t really a step-by-step, because I think the specifics are pretty tailored to my needs. It’s more an example of the possibilities.
In Musicbee:
I created a filter that would collect all of the files I wanted to study.  These were mp3 files in a specific playlist where Album Track Count for the albums they were on was 6 or greater.  I could have also created an auto-playlist to the same effect.
I selected the fields I wanted to study and entered them in the following format under Edit→Edit Preferences→Tags(2)...’export to clipboard’ Tags.
‘<Album Artist>’;’<Album>’;’<Album Artist> <Album>’;<Rating>;<Album Track Count>
The third field, <Album Artist> <Album>, is a unique key I realized I needed in case some album artists had identically named albums (Greatest Hits, Gold, etc).
To export the data, I ran the filter, selected all files, and did right-click→Send To→Clipboard.
In Libre Calc:
I use Libre Calc for my spreadsheet needs.  With the tags in the clipboard, CTRL-V (or Edit→Paste) opens the Libre Calc “Text Import” dialogue.
Separator Option: Semicolon - String Delimiter: '
Now I’ve got 5 columns of data matching the 5 fields I exported from my MB library in the spreadsheet, one row for each song that met the filter.
Here are the things I wanted to calculate as an illustration of what’s possible. I know that some of these formulas can be combined into one calculation, but I’m not that good at it so I like everything in its own column.
My first new column (F) is a formula
=COUNTIF(C:C,C2)
This counts each row that matches the uniquely keyed field, giving me a count of songs from that album that are in the list.
Next (G) is
=E2/F2
This gives me the ratio of songs in the list to total songs from the album. This is one of my main pieces of data.  I format this as a percentage for readability.
Next (H) is
=COUNTIFS(C:C,C2,D:D,"<>No Rating")
Unrated songs say “No Rating” in the list.  I want a count of songs from each album that have ratings. This counts how many rated songs there are (D) for each value in the keyed field (C).
Next (I) is
=SUMIF(C:C,C2,D:D)
This gives me a sum of ratings (D) for each album (C).
Next (J) is
=I2/H2
This gives me an average rating (among rated tracks) for the album in C.
I copy these formulas down to each row in the spreadsheet.
At this point I have all the data I need for each album and I want to remove duplicate rows to just show one line for each album.  Getting rid of duplicates will change the calculations, so I just want raw numbers to remain.
I copy columns F through J and paste them as “numbers only” in columns K through O.  Then I delete F through J so K through O shift left to become the new F through J.
To remove duplicate rows select all of column C (the key row). Data→More Filters→Standard Filter.  Change the first field name to none.  Click + next to Options and select “No Duplications”
This just hides the duplicate rows, but I don’t want them there at all, so I copy everything to a new sheet.
I want to use the percentage of total album that appears in the playlist and the average rating across rated songs to create a Desirability score.
Desirability is Percent of Album in List times Average Rating, so Column K reads
=G2*J2
Copy to all rows, sort descending, and I’m done.
I hope this helps someone somewhere.
