Author Topic: Find Artwork issue  (Read 734 times)
drizzerx
Hello,
When having a bunch of tracks without album cover, I used to automatically get them through Right Click -> Auto-Tag By Track -> Update Missing Artwork, but now this fails on every single track with "No match found". What I find weird is that the player sometimes automatically finds the Artwork when I start playing a track that doesn't have it and I have to right click the artwork and then click on "Paste add" for it to save it to the track. This is annoying since I have to go track by track checking if MusicBee finds the artwork and manually saving it each time.
Is there a way to fix the "Update Missing Artwork" option so It finds the artworks the same way the player automatically finds them when playing a track that doesn't have it?
Any help would be really appreciated.
Hi, welcome to the forum!
There have been some recent updates with artwork. Try updating to the patch in my signature.
drizzerx
Thanks for your answer and for welcoming me :) !
I already installed the patch and I still have the same issue  :'(
https://www.youtube.com/watch?v=99xEQYRVjqc
It looks like there is an inconsistency between those 2 functions when there is no album tagged.
If you re-download the patch it should now work as expected
drizzerx
Steven,
I don't know why it didn't work the first time I patched it, but now it works!
Thank you all for your help  8)
