Author Topic: CPA:console  (Read 3736 times)
Clarence
CPA: Centralised Player Alignment
Variant: console
CPA:console :
DOWNLOAD:
CPA:console
CPA:console_blue
CPA:console_red
CPA:console_green
I hope you enjoy the skins.
[NOTE 1] The display screen font used in the above images is 'The Led Display St.ttf'. It is an original design by southype and is free for personal and non-profit use. Available at http://www.southype.com or via dafont.com at https://www.dafont.com/the-led-display-st.font
[NOTE 2] This skin is part of a series designed to keep the player at a fixed width and central to the screen even when used on a higher resolution monitor e.g. the player stays at fixed width and centralised...the screen either side of the player takes up the stretch.  So if you have a very large monitor and want the player to stretch from left to right side, this is NOT the one for you!
HirriAshana92
thank you clarence for your great skins.
i like this skin and the other one that stays in middle of screen.
it says part of series. will there be more and how many?
Clarence
@HirriAshana92  Thanks for your very kind comment. I'm glad you like the CPA skins.
In answer to your question, there will definitely be at least one more in this series. I'm still putting some finishing touches to the skin but here's a sneak preview of the the player as it stands at the moment.
Let's hope you'll like that one as well. ;)
HirriAshana92
this will be good i think. look forward to this next skin.
thank you for showing.
