I assume you're trying to remove one date from one file, correct? The "custom" column is populated by a custom tag, which you created, right? Find the track(s) that have the date you want removed, and using the Tag Editor delete the tag. If my assumption is not correct, perhaps some more information about this column and a screenshot would be helpful.
