Author Topic: Dowload songs and they appear twice. why  (Read 1999 times)
lady
new to Musicbee, Love the player, easy to use. Reminds alot of Windows media player. The sound quility is great.
issue is, I download alot of music, noticed that after I download and close the player, and reopen it, the songs I downloaded, appear twice, not sure what I'm doing wrong to add them to player. Thank You
Welcome to the forum.
In order for us to determine what you're doing wrong, you'll need to describe what you're doing.
lady
i download the music track, add it my music folder, then go to musicbee, open  Add Files to Libary, find the song from the drop down box, click to open to add, after I add it I check the edit, fill in the empty fields, then when I close musicbee, and reopen it later, I go back to play track and I have 2 tracks, one plays as the other does not.
Can you tell us what the file paths of the two different tracks shown in the library are? It sounds like some software may be reorganizing the files once you've tagged them.
