We are using the latest version of musicbee and have the following when deleting files via musicbee.
This is the CD we want to remove.
This is the folder of this CD, now with files
We are now going to delete the files via the database
After deleting in the database, the folder is empty
But they are still in the database
As you can see it can no longer be called because the file no longer exists.
So what we do now is then select all files again and click on delete again and then it will also be removed from the database
