Author Topic: I DON'T want to use "/" as a separator.  (Read 517 times)
DustyTill
Hi. In the Windows 10 explorer, artists that contains "/" have multiple fields separated with ";", whereas in MusicBee it's not separated at all. I want Windows to be like MusicBee, is it possible? I got this issue only mith MP3, not FLAC.
Last Edit: May 13, 2020, 02:16:04 PM by DustyTill
I may be misunderstanding what you're asking. But it seems like your question is about a Windows function. If you want Windows to be like MB, you should probably talk to Bill Gates. Or one of his developers. Or perhaps find an appropriate Windows forum and post there.
MB uses ; as the separator.
It sounds like Windows may be using an old convention for separator characters. There are some Windows shell extensions available to help bring it up to date.
