Author Topic: Building a `Hi-Res` filter; Sample Rate, Bitrate, Kind  (Read 1440 times)
AaronM
I'm trying to build a filter with my `Hi-Res` files, I can get most of them filtered, but having an issue using the `sample rate` is there a bug or am I not doing it correctly? I'm assuming it just takes the numbers, but it seems  to autocomplete off artists, and not sample rates of songs?
This is the filter I'm trying to build.
This is one of the files, sample rate is 96 kHz
If i select ...
Sample Rate 'is' 96 all my files show up. (Not what I want)
Sample Rate 'is not' 44.1 (Doesn't work, doesn't allow periods)
Sample Rate 'is greater than' 96 all my files show up. (Not what I want)
Sample Rate 'in range' 96  to 768 no files show up. (Not what I want)
I started playing on Bitrate, that kinda works (as expected) but isn't good because if I filter on 2000, some songs that drop below that don't show up, which is obviously what i don't want.
I hope this makes sense...
frankcreed
I think you can use 'Sample Rate > 49000' and/or 'Bit Depth > 17' - that's what I use.
