Hi
since this problem has occupied me more and more I've decided to ask for help here.
I remember there was a major update where some technical thing about the data base was changed. Things changed like Playlists load faster and search is faster too, which is nice.
But I am pretty sure it is since then that MusicBee starts a process regularly occupying all the CPU power. Even on my gaming machine this takes a long while and is disturbing. But it makes it absolutely impossible to use MB on any low tech machine like my old netbook, which is bad cause playing music is a perfect task for a power saving low tech device.
The process takes so long there that it never ends and of course you can do nothing else simultaneously, including playing music with MB. And it happens way to often to ignore it.
I'd be happy if there was a solution for this. I think it is nonsensical to return to the old data base, but maybe options to control, suspend or schedule this process would be great - or more importantly - to separate the process from the one playing music. The music must never ever stop
I use the portable version, if this matters.
Iso
