Hi buddies,
My aim is to normalize a large set of MP3-tracks
permanently (= not via ReplayGain, because my FIIO-player does not support that).
The page
https://musicbee.fandom.com/wiki/Analyze_Volume says "No adjustment is made to the sound data in the music
file itself (unless you choose the permanent adjustment option)....". The part between brackets suggests that there is a "permanent" option in the "Analyse Volume" pop-up, but I don't see that.
Does anybody know how to select "permanent"?
Moreover, I want to
avoid clipping, rather than receiving warnings for the case of clipping.
As far as I can see, there is no setting which allows to completely avoid clipping; right?
I thought of a workaround by using the "File Converter" rather than "Volume Analysis".
In the "File Conversion menu. I'd tick the option "permanently adjust volume" - assuming that this does not work through ReplayGain.
This workaround may theoretically lead to quality loss because it probably applies resampling to the tracks.
Looking forward to some light on these items - with thanks in advance!
Cheers, Herman
