Author Topic: No artwork in google search .  (Read 6621 times)
user73
Hi guys
As the title says i faced this problem On and OFF. Currently i am using latest version and it was working fine with the latest version too but just one fine day as i search for artwork and clicking google search it just stopped showing any result.Below screenshot is just an example of a song buy tried many other songs too but now now google search shows no results.I'm using Musicbee3.37367.
Thx in advance
thats already fixed in the patch version:
user73
Yes ...its working fine now after i copied this patched version.    :)
 and Thx for quick reply.
user73
Hi again.
After new update its not working again.I'm using 3.3.7477 now and I tried to copy the above patch but no success.
Its nothing to do with the musicbee release. It looks like google have effectively made extracting full size original images from search results impossible so I will likely remove the functionality
user73
thx steven for quick reply.
It's sad its not working anymore as i used that feature a lot. :-\
Bing images may be an acceptable substitute  https://www.bing.com/images
great minds think alike! i have just finished implementing it and seems to be working fine so i will post an update a bit later
uses bing in place of google for album covers and artist pictures
or v3.4
http://www.mediafire.com/file/rkx9mn38mybdpaa/MusicBee.zip/file
Last Edit: June 25, 2020, 12:03:56 PM by Steven
Great minds indeed. Thanks Steven.
Since I'm using 3.4 exclusively at this point I'll wait until the next alpha.
or v3.4
Thanks. Will test shortly.
EDIT: Working just fine. Thanks again.
Last Edit: June 25, 2020, 12:35:39 PM by phred
user73
:D working flawlessly....rather faster then google images.
using v3.4 patch
Many many thanks thanks  ;D
using v3.4 patch
Just a heads up ... 3.4 is an early alpha version. It's a very stable alpha, but it's still possible bugs may show up. There's no timetable for it's 'official' release as it will go to beta first. If you're concerned about using an alpha version, you have options:
1- keep using your current 3.3 version - you can apply the latest 3.3 patch over the 3.4 patch you just applied.
2- download the portable 3.3 version and place it in a completely new directory and then apply the 3.4 patch
user73
thx phred for your concern.this much im aware there could be bugs but right now all seems to be working fine so im good with it.If i face any problems then i will do as u advised.
