Author Topic: copy folder don't work  (Read 929 times)
Dpmusicbee
Hi
after i edit a file and try the copy folder option in mb it won't overwrite the file going to the main drive with a new copy. i'm coping from one drive to another with the same file info. i have to delete the old file from the main drive after the file is moved. any rhythm or reason this would be happening.
Thanks
Dbee
I think MusicBee is (wisely) cautious about overwriting files. If you use "copy to organized folder" there's an option to overwrite existing files.
Latest patches (3.5/3.6)
Dpmusicbee
ok where is that option in mb i don't see it Thanks.
Select the file(s) > right-click > send to > Folder (Move)[or Folder (Copy) [or Folder (Replace)]
Dpmusicbee
that is what i've been doing but it won't overwrite the files with the same name it just add them to the folder. Thanks
Dpmusicbee
