Author Topic: Album view on MB 3.3.7367 Store  (Read 1195 times)
Daiman2020
I have MD from Windows Store and Portable for testing settings and configuration before i do it on my main PC which has all the music.
I have noticed that on MB 3.3.7367 Store when you change the view from left panel to Albums (the test music i have is in one folder (compilation album - Album Artists is the same)
https://i.imgur.com/PJVPdJq.jpg
It shows all Albums as the first track only,
One more issues is that Artwork for this Album is the same as the first track in the Album, this one is the same on the portable version too.
https://i.imgur.com/kj79OUe.jpg
If anything seems ok due to settings and can be fixed from the settings/preferences...etc, please help
i am not able to reproduce any issues and i am sure this is the sort of thing that would have been reported already if there was a bug.
Perhaps check your Sorting/Grouping settings for how an album is defined
Other than that I have no suggestions
Daiman2020
Sorry i couldn't update earlier and thanks for the reply Steven :) " YOU HAVE DONE A GREAT JOB"
Yes, under grouping, if i enable "files for each album are organized in their own folder" the first issue appears, I'm not sure why, because tracks are saved in this way on my PC, anyway, i have selected the 2nd option "the following fields define an album" and this issue is solved.
But the 2nd issue where Artist Album shows Artwork from the 1st track " i have tested on 2 PCs and 2 different libraries with default settings" still the same. not sure if i have missed something in settings.
