Author Topic: What external applications are available for MusicBee?  (Read 25801 times)
stardepp
Can we make this topic a collection for possible external applications? Which ones do you know?
Last Edit: May 01, 2020, 05:54:37 PM by stardepp
stardepp
1. Album Art Downloader
https://getmusicbee.com/forum/index.php?topic=28212.msg156499#msg156499
Spek:
http://spek.cc/
C:\Program Files (x86)\Spek\spek.exe "<URL>"
I also have Picard and Fakin the Funk (although the command line interface on the latter hasn't been working lately)
stardepp
Many thanks for your contributions.
@frank What do you enter in the Picard Parameters section of MusicBrainz?
EnduringGuerila
I just tested Picard and it seems to work fine with the parameters set as "<URL>"
Thanks for recommending Spek, just added it.
Music Stats at Last.FM
My MusicBee Skin
My Portable MusicBee Setup (panel layout saved in \MusicBee\AppData\Saved Settings\Layouts)
Picard works better with "<URLs>", otherwise it's going to open a new instance for every file.
EnduringGuerila
Hey sveakul,
Probably wouldn't have mentioned this but your list of external apps is full and I don't want you to be limited.
You can add a button to your toolbar to open the selected track on Explorer without adding explorer as an external app.
My MusicBee Skin
Hey sveakul,
Dang if it don't!  Thanks EnduringGuerila, missed that one for sure!  NOW to find that new tool..  8)
EnduringGuerila
Hey sveakul, Probably wouldn't have mentioned this but your list of external apps is full and I don't want you to be limited. You can add a button to your toolbar to open the selected track on Explorer without adding explorer as an external app.
Lol, glad to help
My MusicBee Skin
New tool added was r128gain (https://github.com/desbma/r128gain) for checking peak dBFS value and LUFS loudness level but not adding tags;  MB Tool entry, assigned to "G" hotkey:
application path:  C:\Windows\System32\cmd.exe
parameters:  /k c:\r128gain-win32\r128gain.exe -d "<URL>"
so_la_la
Mp3directcut...
Desiccate...
Last Edit: May 19, 2020, 01:19:22 PM by so_la_la
Music Bee 3; EAC; Media Monkey; MP3Tag; Synology NAS 115 with Logitech Media Server; RPI 2 with Hifiberry; One Plus X LOS 14.1; [Nokia Lumia 620 WinPhone 8.1]; [Moto G XT1039-CM13]
Humphrzy
