Author Topic: Printing Album Lists with Album thumbnail  (Read 937 times)
wonderdog
https://i.imgur.com/mbMCrct.jpg
Is there a way to print exactly the way the Library Report shows album artist, album, artwork when I run "preview"? See image attached.
If I try to do any or the exports HTML, CSV, M3U, TXT I don't get the same results. Under CSV, M3U, TXT i lose the album thumbnail. If I save under any of the HTML I get the Album thumbnails but no album artist or album, just the JPG info under the thumbnail.
The way the "Library Reports" generates the list before any export is what I am hoping to be able to print. It's alphabetized and simple, just album, artist and thumbnail.
Thank you
That report is generated by the "Additional Tagging Tools" plugin, so you're best off asking about it in the thread for that plugin in the plugins section.
