Author Topic: Android remote  (Read 94190 times)
Sheamus
Running the no notifications version on my HTC Explorer A310e, but even though I can get the option to display lyrics they don't seem to display. Don't know if this is a known issue or if I'm doing something wrong.
kelsos
brainfryd if you check the topics page 7 there is a version posted that won't crash on corrupt image data.
Sheamus, In this version the lyrics support was weird. I think that it would only give you lyrics if the track had embedded ones. Or if the lyrics where already downloaded when you requested them something.
kelsos, how about setting up your own new topic so new links can be provided on the first post?
i imagine it would be quite hard for new users to find the appropriate download links now and then i can lock this topic
kelsos
I was thinking on postponing it till the new version but yes it would be better to create it now, to make things easier.
this topic is closed - a plugin has been created by Kelsos on this topic:
http://getmusicbee.com/forum/index.php?topic=7221.0
