Author Topic: mbp and m3u files  (Read 2786 times)
louf
Greetings, When exporting a playlist to my windows folder, I get two files per playlist a .mbp file and a .m3u file. Do I need both files? I'm importing the playlists to my Garmin Vivoactive 4 watch? Thanks, Lou
The MBP file can only be read by MB, so the file you should be using is the M3U.
Exporting a playlist should not be producing two files per playlist. Which begs the question, how exactly are you doing the export?
louf
Thanks phred. I see the error in my ways, I was using the same folder for playlists as well as for exported playlists. Now I use two folders "playlists for .mbp" and "exported for .m3u" and then select files from exported playlists for the watch. Thanks again.
Glad to hear you figured it out. And thanks for letting us know. This may help other new users.
klh
And help it does. Here's exactly where the paths are set.
