Author Topic: filename rename  (Read 1041 times)
Dpmusicbee
Hi all,
i'm using MB 3.3.7367 and i've created some customs fields. all is working except when i do a file rename of file it loses all custom info that i enter after the file rename. does anyone know why this would be happening? also when mb updates come out does the end number change so you know an update is available?
Thank You.
Dpmusicbee
Dpmusicbee
i using ReName to rename i use special characters in the filename.
I have no idea what that means. Can you show us a screenshot of what you're doing?
Dpmusicbee
by playing around with mb i got it figure out. Thanks for the support.
Dpmusicbee
