Author Topic: Accessing language in lyrics tag  (Read 691 times)
djimy
In mp3, the UnsyncedLyrics tag is saved as "lan||Lyrics of the song here". I'd like to access "lan", or the raw UnsyncedLyrics without "lan" removed (like Lyricist).
Is that possible?
Thanks for the help!
This sounds like a good choice for wishlist item.  In the meantime, you can access that field (if present) from MusicBee by assigning an External Tool tagger like Kid3 to a MB task bar button and calling it up with the tagger:
djimy
Ok, I figured as much...
Using an external tagger tool would only allow me to individually, manually look at the tag, correct?
djimy
I've resorted to using the Language tag instead, thanks for the help!
