MB version? Help > About
Installer? Portable? Windows Store?
Wired sync or WiFi sync?
Music app on device?
In Device Settings is the path and format set correctly for the device?
Hi phred,
My MB version is the latest one, 3.3.7367, used the W10 installer from the downloads page
It's using wired sync, and the default music app I've been using is Muzio Player, which can be found
hereI've seen other music apps not sync their playlists correctly anymore either, though
Upon installation of other apps they sometimes do/sometimes don't recognise the .m3u files, not sure why
Device settings is definitely correct, since all my music tracks DO sync correctly
It's just the playlists that don't sync
Both my tracks and my playlist .m3u files are all on my SD card
Moving both to internal storage didn't do anything for sync unfortunately
I've looked more into this yesterday and I've seen multiple posts about people not being able to sync their playlists in Android 10, which I just happened to update 2 days ago... I'm not sure if this is issue is on Android 10, MusicBee's behalf, Muzio Player or even all three
My playlists haven't been correctly syncing though for.. Around a week or two, I think
