Author Topic: Yet another question about compilations management and display!  (Read 4030 times)
campfred
Good day to everyone reading this! Thank you for your time here. 😁
I want to thank Steve and all other contributors of this application. So far, it's the best solution I have found and I recommended it to a few friends right after starting to build my music library. 💛
Although, while I'm doing just that, I started to get a hard time with music compilations and I'd like to have some help with how to manage them. 😅
The situation I'm facing right now :
I have a bunch of compilations that are not showing properly in the music explorer or at least how I was expecting them to be displayed and handled.
Here's an example:
I have multiple music by Pegboard Nerds. Let's say one original (« Deep in the night ») with its own Single Release album, three remixes by three different artists inside their own remixes compilation (« Deep in the night - The Remixes ») and two tracks from a music label compilation (« Monstercat Uncaged Vol. 8 »).
If I simply tag the tracks like I would have expected where the Album artist are « Snails & Pegboard Nerds » for the Deep In The Night stuff and « Monstercat » for the Uncaged stuff, the first two albums get moved to the « Snails & Pegboard Nerds » artist page and the last one to the « Monstercat » artist page.
I'm content of the Monstercat one as it enables me to find every compilations Monstercat made in one place (Great!).
Although, the « Snails & Pegboard Nerds » was indeed off. (Example)
But, even if my search through the forum didn't give me much helpful info (I probably don't know the right terms to look for. 😄), I learned through a forum message by psychoadept that using the same seperator (« ; ») than with genres enabled me to specify two seperate artists in the Album Artist field. So, that's corrected even though it will make it display weirdly on any device that I'm gonna sync the files to. (Example of how it is now after this detail)
Now, where the difficulty starts is when I start to add other artists in the artist tags.
It's excellent in the sense that it enables me for example to get everything that MUZZ made and without having the other songs that were in the remixes (that MUZZ didn't touch at all) thrown in there with it. (Example)
Although, it creates duplicates of the album with only a single track inside each of them. 🤨 (Example)
This gets even worse if I add the Uncaged compilation to the mix. 😬 (Example from the Pegboard Nerds page and Example from the Monstercat page)
So, my question is : How can I tag everything so that the albums stay consolidated but when I go in the music explorer and say I click on Pegboard Nerds because I want to listen to everything that they made, I get shown all the albums they're in and it only shows me the tracks they are involved in? I really need to figure this out first before continuing to move everything to MusicBee since it's gonna become ugly really fast. 😅
Bare in mind I already have the Track Artist tagged properly with the Artist, Guest Artist and Remixer Artist fields set up on all of my songs. It's pretty much required for me to fill that properly for use in Tractor. Otherwise, it'll be through Tractor that I'll get these details filled in anyway. But yeah. Maybe this will be helpful to achieve what I was expecting to happen on the app?
I also understand how it can be desirable for people to not have their artists view polluted by all the artists they don't care about that were in the compilations they imported. But, I'm willing to trade that for what I'm trying to get. 😝
The simplest solution is to tag Various Artist albums with the Album Artist "Various Artists" or mark them as compliations and then use your library rather than Music Explorer for this purpose.
To start off I'll admit I haven't read and digested your question in detail. (sorry)
So if other members do, and have better and more specific suggestions; please feel free to ignore my response.
I think it is a very bad idea to have multi-value 'Album Artist' tags.
It goes against the basic principle of what 'Album Artist' is, and what it's purpose is, and it can easily result in undesired outcomes.
It would be much better to create a custom tag for your concept of 'Album Artists', and leave 'Album Artist' as a singular tag.
campfred
So, just to be sure I understood right, the solution you're suggesting to the problem I'm having in the Music Explorer is...to not use the Music Explorer? That's not even a workaround solution. I must have understood wrong. 🤨
What are you doing in the b Music Explorer that you can't do as well or better in the library?
That's exactly the solution. Music Explorer is a non configurable mix of library data and external data based on album artists. You will never achieve the result you want of seeing all tracks an artist appears on in Music Explorer while keeping albums grouped together.
Music Explorer is not the right tool for the job.
I'll admit the obscene overuse of Emojis and extreme amount of background info also made me zone out on a lot of your OP, so maybe I'm misunderstanding what you're looking to achieve.
Last Edit: April 22, 2020, 07:51:10 PM by frankz
campfred
Yeah. The question isn't actually a simple question. It's more of a behaviour from the app that doesn't seem right and me trying to understand what I'm doing wrong with it.
And I get what you're saying with the Album Artist. Although, having the usual name say « Snails & Pegboard Nerds » results in what I said earlier where I would get « Pegboard Nerds », « Snails » and « Snails & Pegboard Nerds » in the artists list. It also messes up the Last.FM scrobbler as it starts to think there's that third artist instead of the first two.
campfred
Using the nice and neat interface that was developped to listen to music by artists for example.
campfred
Sorry about that. I don't like having a cold and bland tone in my messages. I'll stop it.
You don't need to apologize.
It's just that we're enthusiasts here who mostly pop in and out to see what problems potential enthusiasts might be having that are preventing them from being fellow enthusiasts. Slogging through a lot of very detailed but not very relevant to solving the problem specifics and high-style messages puts me in skim mode. I was more explaining why I may have missed the thread of what you were looking to do.
Library with album and track view will get you very close to what you want out of the box. We can help move and tweak things from there.
Why and how would your 'Album Artist' overflow or interfere with your 'Artists' tag?
They are different entities. For regular (popular music) albums they will often be identical, but they can also have nothing in common.
You also mentioned scrobbling.
(I don't have much expertise on that myself)
Perhaps it would be a good idea for you to digest the input you have received for now, and then see if you can split/narrow down each separate issue or question that remains, and give each one it's own thread?
campfred
It's okay. I don't hold it against you for that and I thank you for trying to help people on the forums. Your work is super appreciated. :)
campfred
What? Where did I say that the Album Artist was interfering with the Track Artist? That's not what I meant. If I mentionned that, please point it out to me and I'll correct it.
It's also only a single issue. So, I can't really split that into multiple threats. Sorry!
I was responding to:
I may have misunderstood. I am not approaching all this with surgical knives at the moment ;-)
And (just to be sure in case I understand correctly what you are suggesting) please don't edit messages that you already posted and have received replies for.
It would affect the coherence of the thread and make it harder to understand for others that stumble upon it later.
campfred
No problem. Nothing against you.
And yeah. I encountered a 502 error when submitting my response which required me to resend it but it turned out my last part was missing. So, I edited it to bring it back. Hopefully it won't happen again!
