Author Topic: MusicBee Maximize Bug – Turning off the "skin window borders"' option DON'T WORK  (Read 1675 times)
Teddy
Musicbee opens normally as in the image below (showing toolbar)
If MusicBee launches maximized, it looks as it should. Maximizing it while it's running makes it look like this.
After a few minutes running the Musicbee and coming back to run another album the toolbar disappears.
+ Turning off the "skin window borders"' option DON'T WORK
Is there a solution? :'(
Last Edit: April 21, 2020, 08:54:42 PM by psychoadept
Off-topic, but curious:
Why and how did you change the font colour of your message?
It's now unreadable for all members using the dark forum theme.
There are nine pre-defined font colour options you can choose that work well for both the light and dark forum theme.
I am asking because this is happening once in a while, and I truly don't understand why.
Probably has something to do with the wysiwyg editor. I removed the color tags.
