Author Topic: Observation regarding something I noticed when resizing the MB window  (Read 640 times)
wasp
My question relates to the column browser and resizing MB.
When the column browser is set to "horizontal", then all the columns of the column browser automatically adjust when resizing the MB window.
When the column browser is set to "vertical stacked" or "vertical side by side", the column browser columns do not auto adjust when resizing the MB window.
So if you currently set the column browser to "vertical stacked" or "vertical side by side", and the columns to a specific width and afterwards you resize the MB window, you need to go back to column browser and adjust each column individually for all columns to be visible.
Was this feature not implemented on purpose?
wasp
I don't know if this makes sense (still discovering so many things with MB) -  but when you right lick on the header of the column browser, under the Reset, I believe would be good to get also an "Auto-size All Columns".
