Author Topic: ScrobblerBrainz: a plug-in to scrobble tracks to ListenBrainz  (Read 26492 times)
Eggaian
  • You all know exactly who I am. Now, say my name.
If your profile is at the link below then you have to be more specific because I don't see MusicBrainz-linked scrobbles there.
https://listenbrainz.org/user/diaken/
As for the version number, where exactly does it say its 1.0.0?
Go to charts and you'll see. For example, my charts display 65 listens for Trainwreck at 7th place and it's linked to a musicbrainz entry. Then you see Trainwreck again at 25th place with 13 listens, this time, not linked to a musicbrainz entry.
When I hover over the plugin, it says it's 1.0.0.0 version. Also when I look at the 'details' tab on its properties.
karaluh
Ah, in the File Explorer. I'll look into this.
As for the other issue it looks like something in ListenBrainz UI is broken. On the link below in the "Top Recording" section the first two places are occupied by the same song and both of them are MB-linked to the same recording.
https://listenbrainz.org/user/Diaken/reports/?range=week
ListenBrainz plugin for MusicBee:
https://github.com/karaluh/ScrobblerBrainz
Eggaian
Aight, let me know.
Yea, you're right. it's the same song but from different releases and they both link to Turn on the Bright Lights for some reason. But did you take a look at my top artists in the 'all time' range? Then you'll see what I was saying about Trainwreck.
karaluh
Aight, let me know.
Yes, that also looks like LB issue.
Eggaian
Just reported the issue, let's see what they say/do.
Also, did you look into what I told you about the latest version of your plug-in?
karaluh
Not yet, sorry. On the bright side I expect this to be an easy fix that'll be included in the next release. No ETA though.
Shingo
Doesn't seem to be working for me, I put the LB token in the plugin config but it's not scrobbling anything.
Applying/saving and restarting MusicBee doesn't help (also, the token disappears every time I go back to the preferences, I don't know if that's supposed to happen).
karaluh
Definitely not. It looks like the token is not saved in the preferences, I'll look into this.
karaluh
Should be fixed now in the v1.1.1 https://github.com/karaluh/ScrobblerBrainz/releases/download/v1.1.1/mb_ScrobblerBrainz.dll
Shingo
It's working now, thanks!
Shingo
I was wondering... would it be possible to sync the "loved" tracks between MusicBee and ListenBrainz via the API? Is that something you're planning to implement?
karaluh
Eventually, yes.
ThY
Eventually, yes.
Hello, i just quit the Last FM scrobbling to test the ListenBrainz one, and discovered your plugin, for which i thank you :)
Still no plan to implement the "loved" track feature ?  :)
karaluh
Eventually, yes.
You're welcome, I'm glad you find it useful.
As for the loved tracks, currently I'm unfortunately busy with life. I plan to return to regular development, but I don't yet know when. When I do, I'll put this feature on top of my TODO list :)
